feature000
feature000's Achievements
  1. Did you clean the air filter?
  2. Stroker domes is the only answer, Shortys racing also sells them or Pasions racing either of the will hook you up
  3. I tried that and had leaks all over the place, ordered stroker domes or cut domes from shortys, but also heard that patriots racing sells them plus it looks sleeper with no plate in place.
  4. I always hit it with a rock and it always comes open. Sucks though when you are riding when there are no rocks
  5. Wiesco also sells, well its made by Cometic a thicker gasket kit whick just include a thicker gasket for the head to compesate for the 2mm stroke. I am running the wiesco pistons and stroker domes putting it all in today and tomarrow.
  6. I am getting a 4mm stroker 5mm long rod crank, with wiseco 795 series pistons I got my cylinders ported by LA sleeve for the stroker long rod crank. The problem I have run into is I wanna run a pro design coolhead what do I need to do? Do they sell some sort of spacer for the head. Please help.
