getonit Posted February 21, 2004 Report Share Posted February 21, 2004 do you have to heat up the primary gear to get it back on the the crank shaft mine is not coperating whats the trick if there is one,thanks for any help Quote Link to comment Share on other sites More sharing options...
ruff_rida69 Posted February 21, 2004 Report Share Posted February 21, 2004 you should'nt have to heat it up, when I did mine I left it off like 2 days and when I started putting it back together it slid on perfectly with no problems Quote Link to comment Share on other sites More sharing options...
getonit Posted February 21, 2004 Author Report Share Posted February 21, 2004 i have a new crank maybe the keyway just needs a small amount of filling down,i had to use a gear puller to get it off so im wondering what the next move should be Quote Link to comment Share on other sites More sharing options...
yamaha350 Posted February 21, 2004 Report Share Posted February 21, 2004 first make sure there is no flaws in the gear surface or the crank surface. measure them with a set of calipers too. also what crank is it? if you can get ahold of another gear try that. Quote Link to comment Share on other sites More sharing options...
getonit Posted February 22, 2004 Author Report Share Posted February 22, 2004 the crank is one of the hotrod cranks i got the gear to slide on nice after i did a little filing on the keyway,checked it over and over again on the top its all good now i have the motor back in the the bike just finishing up the little stuff Quote Link to comment Share on other sites More sharing options...
