evryone put your cheap mods that you have done up on this post so evryone can get ideas for very low cost mods you can do to make the shee performe and look better.
for example relocating the coolant bottle
thanks
Trim your fenders
Ditch the air box (if you are still running the stock air fillter setup you are and idiot)
ditch the parking break
Ditch the TROS
get an inline fuel filter
Deck the head (most shops do this for realy cheap with a core)
do not use Yamalube (try a synthetic premix)
make sure you have a jet kit
polish anything you can (most parts are aluminum and you can save alot of $ by doing it your self)
Go on a diet (the cheapest way to drop a few pounds off of your shee)
And make sure that your right thumb is in good shap (it will be doing alot of mashing)
and once you've done that, break out the dremel, hack off all the "extra crap"
off the clutch perch, then polish.
i heard once of poeople taking turbo's out of older vans and with some elbow greese would put them in but i dont know how long there neinge lasted i wouldnt recomend it but im curios about it
Must be a new trick what the heck you mean cut the swinging arm back??? Make it shorter?? how the hell ya keep the front end down I was gonna go longer. Maybe I'm thinking the wrong idea or misunderstood ya.
Tip I got from MEAT (thanks), 6 bucks at auto zone anodized paint in a can. clean tape up and shoot your hubs.
I did the same thing a couple months back with the red anodized paint and looks awsome and is pretty durable too.
Anozized paint works good!
But back to the real mods
Install grease fitting to axel carrier
(Pretty easy get a small grease fitting from auto store, hardware, wherever, center punch a hole in the center of the top half of the carrrier, drill it out. Now comes the work! Get to the axel collar, after you've taken your whole axel apart :rolleyes: that shouldn't take long <_< . Then line up the grease fitting hole with the collar and drill 2-3 holes, depending on drill bit size, don't get carried away. This keeps the axle well lubricated.
Ahh another MOD
Temp Gauge, look it up, there are a couple threads already.
*Lian :D Turbos out of an old van? Really? Who wants to hear more about that? I would never ever suggest using any parts from an old van to mod your banshee. Banshee can be turbo'd, I've seen a kit a while back on EBay, very nice tdo4 hybred turbo, for about $1500. If your a good fabricater I imagine you could apply a turbo to a banshee for less.
Keep posting Mods
ive seen pics with banshee's with turbo's i would never put one in my banshee but you can soposly take a turbo form some old van and put it in a banshee or a blaster
