1_bansheenutt Posted February 8, 2004 Report Posted February 8, 2004 I changed my oil today and went riding afterwards, noticing my clutch was slipping. It never did this until I changed to a synthetic oil. Has anyone else ran into this problem? Will the clutch grip with synthetic oils??????? Guess its back to castrol 10-40 for me! Quote
lucky13 Posted February 8, 2004 Report Posted February 8, 2004 I HAD THE SAME BAD EXPIERENCE WITH SYNTHTIC OIL. NOW I RUN ATF Quote
1_bansheenutt Posted February 8, 2004 Author Report Posted February 8, 2004 I was wondering man, looks like its back to the old school engine oil, I guess that synthetic is just to darn slick.....I may give that ATF a try, notice any improvements using it? Quote
PlaynSand Posted February 8, 2004 Report Posted February 8, 2004 1_bansheenutt, what brand of synthetic oil did you use? Synthetic oils are great if the proper ones are used , they must be non-friction modified for use with wet clutch applications. The use of automotive oils that are energy conserving or friction modified will cause an early death to your clutch ,synthetic or not. Quote
1_bansheenutt Posted February 9, 2004 Author Report Posted February 9, 2004 OK, Thanks for the info guys. It was castrol semi synthetic, gotta get this stuff out, hopefully it will be ok! Quote
2001SSTBanshee Posted February 9, 2004 Report Posted February 9, 2004 Synthetic oils are great if the proper ones are used , they must be non-friction modified for use with wet clutch applications. The use of automotive oils that are energy conserving or friction modified will cause an early death to your clutch ,synthetic or not. Nicely said. Quote
