n41banshee41d Posted February 7, 2004 Report Posted February 7, 2004 hey guys iv got the shee motor out and ready to build here is what i want to do bore .40 over to fix cylenders wiseco piston kit nos head with 19 or 20 cc domes adjustable timing plate new cluch kit aluminum water impellor trinith 2 into 1 cv carb dyno port 2 into one pipe is this a good set up if i run it on vp race gas? now i wasnt gonna weld the crank but some one said i should ??? do u guys really think its nesassary?if so y..should i have a port job done and if i do will it benifite that much with the set up i have and what whould a good degree to run the timing plate on???any help would be great im really worried about the crank and haveing to tear the bottom end appart so any imput on that is great thanks Quote
FORMULASPEED Posted February 7, 2004 Report Posted February 7, 2004 Weld the crank indefinatly no butts. Mine just sperated with my set up. and this is what I was running .40 overbore, Coolhead 19cc race gas needed in low elevation, Ported,K$N,Boyseen reeds, Trinity 2-1 35pwk, DMC 916, Namura power pistons 14/42 It was a Fn torque monster . I liked it. Quote
. Posted February 8, 2004 Report Posted February 8, 2004 general rule, if you port it....you gotta weld it. You're gonna be at that limit that it might start doing something to your crank. It's all up to you whether or not you wanna go into your lower end. Is this the first new top end going on the bottom end after stock. I'm 40 over, coolhead running 153 psi, pushing somewhere around 55 hp or so and my bottom end was fine when my top end went. I'm running the stock bottom end with this new top end (first after stock) but anything afterward I'm gonna have portwork and such and going to be welding the the bottom end. Quote
mattmans1983 Posted February 20, 2004 Report Posted February 20, 2004 Weld it no matter what. Port it while its apart. Around $50 crank weld from jim @ passionre. He does phenominal work. As soon as he gets the crank he'll have it done and shipped out the next day. Know 4- guys to get theirs done there. Quote
