jasonsb Posted January 26, 2004 Report Share Posted January 26, 2004 I just rebuilt the top end on one of my bikes. No modifications, same set-up. So, I'm running it rich to break it in (25:1). It ran choppy for the first hour. It sounds like it's missing until I hit 1/2 throttle. Then, I tried to take it on a second ride and it died after I pulled away (10 seconds). It wouldn't start anymore. I took the plug off and cleaned it. The plug tip was dark and wet. I cleaned the plug and it started....and again it died after I pulled away. It wouldn't start anymore again. It sounds like a bog or like I'm out of gas..then it just dies out. Could it be the carbs (33 pwk) or an electrical problem? Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted January 26, 2004 Report Share Posted January 26, 2004 well you said yourself that your runnin it rich, that would explain for the box and the black plugs Quote Link to comment Share on other sites More sharing options...
superchicken Posted January 26, 2004 Report Share Posted January 26, 2004 put new plugs in it.theres alot of mynute[small] metal particles being thrown around in the clylinders after a rebiuld.and they foul the plugs up something feirce.try it Quote Link to comment Share on other sites More sharing options...
jasonsb Posted January 26, 2004 Author Report Share Posted January 26, 2004 I will definitely try that! That might be why I can't get the bike to idle also. I keep playing with the idle and air/mix screws, but it's very inconsistent. Quote Link to comment Share on other sites More sharing options...
jasonsb Posted January 26, 2004 Author Report Share Posted January 26, 2004 I bought new plugs and will next try to get the idle and air screws dialed in. ANyone have an idea where to start...I turned everything so much that I don't remember what it used to be set at? (33 pwk keihin) sea level 60-75 degree riding. Will the rich mixture 25:1 keep causing the plugs to be fouled? How long should I run it rich to break the motor in? It has about 3 hours. Quote Link to comment Share on other sites More sharing options...
Yamahammer Posted January 26, 2004 Report Share Posted January 26, 2004 after 3 hours you should be ok start leaning the oil ratio out to atleast 32:1 that may be all the run a bility problems you are having to much oil noy enough gas. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted January 27, 2004 Report Share Posted January 27, 2004 I broke in a (stock) Blaster once by just letting it idle for 20 minutes at a time, along with riding it a little bit.....just enough to get the engine warm and then shut it off. That Blaster ran better and the piston lasted longer than any I had done before.I wonder if that would work for a Banshee, provided it would idle? Of course your's won't idle. What about an oil that can be used at a leaner mixture such as Bel Ray MC1 (at about 32:1 for break-in) or Amsoil (I don't know a good ratio for break-in, I've never used it)? Just a thought Quote Link to comment Share on other sites More sharing options...
yamaha350 Posted January 27, 2004 Report Share Posted January 27, 2004 i run 40:1. and its still a mess when i tore it down, lots of oil everywhere, you should be breaking in your motor with the mix ratio you are normally going to use. Quote Link to comment Share on other sites More sharing options...
