Madbanshee01 Posted January 22, 2004 Report Share Posted January 22, 2004 Hey everyone, I was just wondering if any of you guys have any bends in your shee frame. I have two spots. 1 - is where the grab bar joins to the frame, it bent down. 2 - is the part of the frame infront of the gas tank, i rolled the shee hard one day and that whole part in front of the gas tank, alos the part where the top of the radiator connects to. Well i was just wondering if you guys have any bends and what is the best way to fix these bends with out making the frame weak. Thanks, Jo Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 22, 2004 Report Share Posted January 22, 2004 do a search. go back as far as you can go. i know of several posts that talk about this. good luck! Quote Link to comment Share on other sites More sharing options...
banshee2sick Posted January 22, 2004 Report Share Posted January 22, 2004 I bent my frame around the gas tank the same way. I cut the triangle braces out of the corners, and used a port-a-power to push it back up. then I welded in thicker braces. Quote Link to comment Share on other sites More sharing options...
yamaha350 Posted January 27, 2004 Report Share Posted January 27, 2004 get someone to make you a subframe. it will look better. just bend the other back. or buy a new frame. i hit a sandrail doing 45+ last summer with my banshee, want to try and staighten that frame?? looks like a banana. also for sale Quote Link to comment Share on other sites More sharing options...
