i'm wondering which would give me more power new head or carbs and if i get new cared do i put all the jets out of my stock ones in them or what
The carbs can probably help create more HP since you have a stroker, but it depends on your porting I suppose. The head can add more bottem end and cooling, but its not so much a HP mod.
You will probably need to buy different jets for new carbs as the ones you have will either be the wrong size or type more than likely.
So I guess it depends on yoru needs, you could just get both :)
i dont think i have any porting inless the guy who had it before me did it
A good head set-up is absoluetly going to get you more power and with greater safety from detonation than carbs will. Stock Banshee carbs work pretty well, and unless there is some decent cylinder mods done, they will work just fine. The money is better spent on a quality head.
