   D.I.D is a really good brand of chain and they do come on some of your major brands of dirt bikes as a OEM chain. The downside of the brand is the price. There is other brands of chains that are just as good as D.I.D at a less expensive prices and they hold up hold up just as well. You can check out these companies Motosport.com or Rockymountainatvmc.com and see what they have to offer. Just make sure that you replace both front and rear sprockets when buying a new chain ( it would be senseless and a waste of money to put a new chain on old worn out sprockets ) and also check for worn out drive line parts like upper & lower chain rollers, chain slider and the rear chain guide. Also if you don’t have one yet make sure you look into purchasing a case saver because banshees are prone to chain wack.
  • Like 1
Thanks for the input i did purchase the chain and bought new chain guides and a drw case saver i bought the jt spockets dont know if there any good im building a banshee just doing research
All good stuff. You’ll have zero issues with this combo.
