Best CDI Box
MEW
I forgot to mention this in my previous post. You can also do this!  *** A guy that I ride with had the CDI go bad on his 95 and he bought a used CDI from a 02 and he cut the ends off the 95 CDI and then he cut off the ends off the 02 CDI and he spliced, soldered and heat shrunk the 95 plugs onto the 02 CDI and his banshee has been running perfectly fine since. ***
  • 2 weeks later...
  • 2 weeks later...
On 10/27/2023 at 11:51 PM, ClaudeMachining said:
The Yamaha Banshee engine is not like any other 2 strokes, if it's not oem ignition, it cant work.
Dunno how the engineers did that tho.
Envoyé de mon SM-S908W en utilisant Tapatalk
Pretty interesting indeed. Or the aftermarket engineers aren't good enough to crack the code
