Twomuchsmoke Posted June 17, 2023 Report Posted June 17, 2023 I found a got deal on new mikuni vm or tm carbs? I was thinking 28-32 depending on the setup I want but I want throttle response so I know I don’t want to go to big.my question is I’m getting the vm new shipped to me like 65-70 bucks each depending on size for genuine not knockoffs and I thing the Ty’s are like 85-90 each depending on size. My question is are they reliable and easy to setup.I wanted stock carbs but got ripped off to many times buying used and kehiens are expensive new or used I can’t find a reasonable priced set, I really want oem but tired of blowing money on carbs that are broken or messed up in away.are the mikuni setup reliable?which is better tm or vm? Quote
Jereme6655 Posted June 17, 2023 Report Posted June 17, 2023 Are your precious carbs oem? What’s messed up/broke on them? And what is your motor setup? Quote
Twomuchsmoke Posted June 17, 2023 Author Report Posted June 17, 2023 3 hours ago, Jereme6655 said: Are your precious carbs oem? What’s messed up/broke on them? And what is your motor setup? I need new ones my bike I bought came with knock offs time to change them for the new engine build Quote
Twomuchsmoke Posted June 17, 2023 Author Report Posted June 17, 2023 I bought some used oem and all the tors idle screws we’re screwed on the ring side so the carbs are junk so vm or tm mikuni which is better and easier to tune? Quote
Twomuchsmoke Posted June 18, 2023 Author Report Posted June 18, 2023 11 hours ago, locogato11283 said: Keihin PWK only. I would but there so expensive I feel if ima bite the bullet I should get lectons or smartcarbs if I’m gonna buy pwk’s Quote
locogato11283 Posted June 21, 2023 Report Posted June 21, 2023 I would but there so expensive I feel if ima bite the bullet I should get lectons or smartcarbs if I’m gonna buy pwk’sLectrons are junk. Smart Carbs aren’t that smart. Quote
specialblend07 Posted June 21, 2023 Report Posted June 21, 2023 Mikuni carbs are junk. PWK are the best/easiest carbs to use Quote
Twomuchsmoke Posted June 21, 2023 Author Report Posted June 21, 2023 20 hours ago, locogato11283 said: Lectrons are junk. Smart Carbs aren’t that smart. Lectons and smart carbs are junk foreal? I thought and heard always good things about them ,wow so I’m stuck to oem or pwk’s? No lectons or smart carbs then? Quote
locogato11283 Posted June 22, 2023 Report Posted June 22, 2023 Lectons and smart carbs are junk foreal? I thought and heard always good things about them ,wow so I’m stuck to oem or pwk’s? No lectons or smart carbs then?What motor are you running? I’ve been running a 24DM on 41PWK for years. Quote
Twomuchsmoke Posted June 23, 2023 Author Report Posted June 23, 2023 It’s gonna be 65mm redline dune ported stock cylinder 4mil. With CPI’s if I find a set. Quote
Twomuchsmoke Posted June 23, 2023 Author Report Posted June 23, 2023 3 hours ago, locogato11283 said: What motor are you running? I’ve been running a 24DM on 41PWK for years. What makes lectrons bad? Quote
locogato11283 Posted June 23, 2023 Report Posted June 23, 2023 It’s gonna be 65mm redline dune ported stock cylinder 4mil. With CPI’s if I find a set.I know for a fact that Cam will recommend PWK. I don’t know why you’re looking at two carbs that he doesn’t use. Sounds like you’re just trying to be difficult. Quote
Twomuchsmoke Posted June 24, 2023 Author Report Posted June 24, 2023 I got a really good discount on lectrons brand new from them 30% off. That’s why I ask. Quote
specialblend07 Posted June 26, 2023 Report Posted June 26, 2023 On 6/24/2023 at 10:45 AM, Twomuchsmoke said: I got a really good discount on lectrons brand new from them 30% off. That’s why I ask. Spend a dollar to save a dime.... Quote
