Chag Posted June 1, 2023 Report Posted June 1, 2023 My Banchee wont kick start but will pull start. if you kill it it will kick start but after a few min of not running you will have to pull start it again. Does anyone have a idea what it could be, reeds? it has the torrs still on the carbs and new plugs. thanks for the help Quote
locogato11283 Posted June 5, 2023 Report Posted June 5, 2023 Check compression. I bet it’s low. If it’s 110 or lower it’s time for a rebuild. Quote
specialblend07 Posted June 6, 2023 Report Posted June 6, 2023 22 hours ago, locogato11283 said: Check compression. I bet it’s low. If it’s 110 or lower it’s time for a rebuild. ^ I'm with stupid. Quote
RagunCajun Posted August 12, 2023 Report Posted August 12, 2023 May be a long shot, but make sure the cross over tube is there if it's stock carbs. Quote
Chag Posted March 26, 2024 Author Report Posted March 26, 2024 it was the TORS module or whatever its called. Once I did the TORS delete and unplugged everything to do with it, it fired up the second kick. Quote
