Muyguapo Posted July 26, 2022 Report Posted July 26, 2022 The threads on my carbs are wore down so bad, where the slide cap screws on, that I can't tighten them anymore. Any ideas other then new carbs, since I'm supposed to go riding in a couple days. I looked on amazon and they have a full set of carbs for around $80, but I'm not sure I want to even bother with those. Thanks Quote
machinegunbanshee Posted July 27, 2022 Report Posted July 27, 2022 Maybe try some plumbers tape and a good, tight cross-thread. Quote
diebog Posted August 1, 2022 Report Posted August 1, 2022 (edited) Order a heliocoil kit. Real easy to use just take your time. Them threads will be steel and last much much longer. For a fast fix get some fine copper wire and stick it down I’m the hole and thread screw in. Edited August 1, 2022 by diebog Quote
Jereme6655 Posted August 2, 2022 Report Posted August 2, 2022 On 8/1/2022 at 12:44 AM, diebog said: Order a heliocoil kit. Real easy to use just take your time. Them threads will be steel and last much much longer. For a fast fix get some fine copper wire and stick it down I’m the hole and thread screw in. Pretty sure he’s talking about the main cap…. To pull the slides out….. Quote
specialblend07 Posted August 2, 2022 Report Posted August 2, 2022 Just drill them out and rethread them. Simple. Or JB weld them on Quote
Muyguapo Posted August 5, 2022 Author Report Posted August 5, 2022 Appreciate replies. Tried the plumbers tape, but it didnt seem to be tight enough. So I put an ad on craigslist and just bought a used one. Quote
