Fr33zypop Posted July 3, 2022 Report Posted July 3, 2022 So I’ve replaced a ton of brakes in a lot of cars and trucks and wasn’t to worried about the banshee but wtf. I can’t seem to fit the new pad on the right side of the caliper. When I tried to put on both new pads the rotor was getting jammed by this raised area. What am I missing here? I watched some videos already but I haven’t seen this issue raised. Because I was about to go for a ride I had a pad that was completely wore off to get it to fit. Sent from my iPhone using Tapatalk Quote
chee_dee Posted July 4, 2022 Report Posted July 4, 2022 On 7/3/2022 at 4:55 AM, Fr33zypop said: So I’ve replaced a ton of brakes in a lot of cars and trucks and wasn’t to worried about the banshee but wtf. I can’t seem to fit the new pad on the right side of the caliper. When I tried to put on both new pads the rotor was getting jammed by this raised area. What am I missing here? I watched some videos already but I haven’t seen this issue raised. Because I was about to go for a ride I had a pad that was completely wore off to get it to fit. Sent from my iPhone using Tapatalk Did you release/remove the parking brake adjustment screw completely? Quote
Fr33zypop Posted July 4, 2022 Author Report Posted July 4, 2022 I don’t have the parking brake setup anymore and was removed before I owned it. I’ll have to research that. ThanksSent from my iPhone using Tapatalk Quote
Fr33zypop Posted August 21, 2022 Author Report Posted August 21, 2022 I could use some help on this. I don’t have the ebrake assembly anymore. This plate on the right. Is it supposed to move at all? I’ve tried to get it to move in with a clamp but it won’t budge. Not sure if it’s seized or what. The only pad I can fit is one with the pad 100% gone. The new one will but the rotor is pinched and won’t fit. Sent from my iPhone using Tapatalk Quote
375hp banshees Posted August 21, 2022 Report Posted August 21, 2022 Slide pins are frozen or caliper piston is froze? Quote
Fr33zypop Posted August 21, 2022 Author Report Posted August 21, 2022 Piston is not frozen and moves fine. If the two slide pins are supposed to move they don’t. I can try to soak them tonight. Sent from my iPhone using Tapatalk Quote
375hp banshees Posted August 22, 2022 Report Posted August 22, 2022 Yes, piston pushes on 1 pad, then draws caliper over ( on slide pins) so other pad pinches other side. Ya know just like cars &... trucks. Quote
Fr33zypop Posted August 23, 2022 Author Report Posted August 23, 2022 I can’t get this to budge so I’ll need to replace it. The Yamaha dealer can get a oem one for 400+ so I’m looking for opinions to other options available online. Anyone have any experience with ones on eBay?Sent from my iPhone using Tapatalk Quote
Fr33zypop Posted August 23, 2022 Author Report Posted August 23, 2022 After finding a rebuild video I found the issue and new pads are in. Sent from my iPhone using Tapatalk Quote
375hp banshees Posted August 23, 2022 Report Posted August 23, 2022 Tell us what it was... So skeeter doesnt do it. Thats what this site is for. There's no sense in making a post, if you don't reveal the answers to your questions,for the next guy/Ky'ean. Quote
Fr33zypop Posted September 2, 2022 Author Report Posted September 2, 2022 Loosened the bolts on the bracket got it moving. I’ve ripped some of the rubber surround but it’s fine imo. I don’t got in water or sling mid. Sent from my iPhone using Tapatalk Quote
375hp banshees Posted September 2, 2022 Report Posted September 2, 2022 Some people said a certain aftermarket brand, was making the pads to thick & werent able to use them also... Quote
