Blue Duece Posted December 22, 2003 Report Posted December 22, 2003 im with SSD something in the right carb....drain the bowl, check the main?..... Quote
bansheelover Posted December 22, 2003 Author Report Posted December 22, 2003 yup, yesterday i checked the bowl and the main and their fine, how do u get the pilot out? do i need a small screwdriver or special tool?? all i have to do to disable the tors is unplug that box?? i thought i had to splice some wires or something also.... thanks again for the responses guys Matt Quote
bizanchee Posted December 22, 2003 Report Posted December 22, 2003 Nope just unplug the box, that should eliminate the TORS as a culprit. I would deffinately suggest you invest in the Tors eliminator kit in the future though Quote
SDD Posted December 23, 2003 Report Posted December 23, 2003 Yes you will need a small standard screw driver. You can go buy a small screw driver for pretty cheap and if the sides of the blade are too wide take a file or grinder and narrow it down some. Quote
98bonerSTOCKshee Posted December 27, 2003 Report Posted December 27, 2003 did you add the t-6's in this time frame?? When I 1st put my t-5's and jetted, My shee was poppin....I didn't get the stinger pipe sealed up good to the tail pipe. I tightened the clamps and wammO! Krank her up, and feel along the exhaust especially the clamps I felt air leaking. Just a thought....maybe time saving though Quote
