Ckooienga1058 Posted May 3, 2022 Report Posted May 3, 2022 Restoring a 99 banshee. Coolant bottle and all the lines. I’m confused on what goes where. So the line from the top of the bottle is the longest. I’m assuming that goes to the overfill of the radiator? On the end of it is like a white connector piece. There is a T on two lines which are just zip tied to the other ones. And one black line that goes from the top of the coolant bottle. Quote
locogato11283 Posted May 3, 2022 Report Posted May 3, 2022 You can toss the reservoir and run the overflow to the ground. That’s what most people do. Quote
Ckooienga1058 Posted May 3, 2022 Author Report Posted May 3, 2022 10 hours ago, locogato11283 said: You can toss the reservoir and run the overflow to the ground. That’s what most people do. I’m doing a 100% OEM restoration that’s why. Quote
caleb90 Posted May 3, 2022 Report Posted May 3, 2022 The top line from the bottle is the over flow and it runs up to the steering hoop and sits in a L tab on the hoop. The bottom hose runs to the radiator nipple Quote
caleb90 Posted May 3, 2022 Report Posted May 3, 2022 The lines with the t are the crank vent hoses Quote
