Conner304 Posted March 30, 2022 Report Posted March 30, 2022 I have a 04 banshee with vitos super stock pistons stock bore pro circuit platinum pipes 240 main jet 30 pilot jet air screw is 2 urns out an tors delete kit my elevation is around 650 to 700 my fuel mix is 32:1 using klotz with 93 pump gas Quote
Keno Posted March 30, 2022 Report Posted March 30, 2022 Swap the spark plug leads, If the miss follows the wire, Cut the wire back and retest. Use DMM to check continuity of the boot. Replace Boot if no continuity. Clean the carbs. A plugged jet can cause issues Sync the carbs at idle using the idle screws. Then back the throttle adjuster out until the rpm raises and sync the carbs using the adjuster on the top of the carbs. Return throttle adjuster at throttle to just a bit of free play. Check for leaks around reeds/intake with some carb cleaner, if idle changes, possible leak. Reseal intake. Check for broken reeds. Adjust air screws for idle. Verify exhaust not plugged with a mouse nest, acorns, ect. Check compression. If below 100 rebuild. 1 Quote
375hp banshees Posted March 31, 2022 Report Posted March 31, 2022 ... and report back so others will know what it was. This site is here for more stuff than... biden BuLl sHiT tHReaDs Quote
Conner304 Posted March 31, 2022 Author Report Posted March 31, 2022 I checked my plugs an I wasn’t getting enough fuel to that cylinder so I screwed my air screw to 1 turn out an it is running pretty good now but I think my jetting is off just ordered bigger jets when they come in I’ll let y’all know how it doing Quote
