Going to be ordering my direct drive clutch cover. Currently i am running fast's hd clutch kit, trying to decide if i should stick with that or get the lock out with the cover. What are the pros and cons to the lock outs? Thanks
10-4.. the clutch cover i want with the reinforment ring, gasket kit and bearing pressed in by direct drive. Is the same price as the direct drive kit redline sells
With a lockup, you can use oem spring, but if you dont have a drag cut tranny, it will be hard To shift at WOT.
Since i'm a wimp, i use oem spring with a slingshot lockup (no new cover needed with that type of lockup).
If i want to shift fast, i have to release the throttle a little bit to shift and i dont use the clutch at all.
Envoyé de mon SM-S908W en utilisant Tapatalk
