NitroObsidian Posted February 2, 2021 Report Posted February 2, 2021 (edited) Hello , i want to buy a kit DC conversion for my Banshee. Can you tell me if this DC conversion work with a ignition MVT Premium ? I have a wire with 60w of power for my led light bulb ,but it in AC current the yellow wire from the stator is my 60w power Thanks you for your answer Edited February 2, 2021 by NitroObsidian Quote
97Screamer Posted February 2, 2021 Report Posted February 2, 2021 Yes, if that digital stator is putting out 12VAC nominal voltage the JL kit from JDS will convert it to DC.Sent from my HTC U11 plus using Tapatalk Quote
Keno Posted February 2, 2021 Report Posted February 2, 2021 Yes, if that digital stator is putting out 12VAC nominal voltage the JL kit from JDS will convert it to DC.Sent from my HTC U11 plus using TapatalkDoes not need to be 12VAC, just >12vac. Voltage will vary with RPM and likely peak at around 40VAC. The kit includes a regulator/rectifier. But otherwise you are correct.Edit: Just to clarify further, the DC voltage after rectification is (1.41*VAC)-(diode voltage drop)=VDC. So if the reg/rec is set to output 14.4VDC and assuming a diode voltage drop of 0.7V and a full bridge rectifier, then you need > (14.4VDC+1.4v)/1.41= 11.2VAC. Quote
