2strokeftw Posted January 2, 2021 Report Posted January 2, 2021 I haven’t had much luck with my last post. Not a single reply lol. So I am going to try again I am in need of a set of oem stock bore cylinders! With all these built bikes doesnt someone have a set of stock cylinders for sale lol I’m located in Missouri and there’s nothing for sale local Quote
the boris Posted January 9, 2021 Report Posted January 9, 2021 I haven’t had much luck with my last post. Not a single reply lol. So I am going to try again I am in need of a set of oem stock bore cylinders! With all these built bikes doesnt someone have a set of stock cylinders for sale lol I’m located in Missouri and there’s nothing for sale local Good luck with that, just givi2you a bump. Sent from my VOG-L29 using Tapatalk Quote
ATV_hub Posted January 9, 2021 Report Posted January 9, 2021 I may be wrong but finding stock 64mm cylinders that do not need a bore may be a challenge, they’re all like 15 years old now, why not settle for a set that have been bored a size or two up? Quote
2strokeftw Posted January 13, 2021 Author Report Posted January 13, 2021 Just saw these replies. Good points lol. But yea I have some oem cylinders at the machine shop now on a stock bore but had some surface rust. So I’m seeing if the 64mm wiseco pistons I had will work otherwise I gotta order the next size up. Since they have some corrosion what would be a safe size to go with? The shop owner said they would probably need bored but he would check to see if they would work with a hone and clean up. But I figured regardless probably good to go the next size so that leads to my question above Quote
Tedder Posted January 13, 2021 Report Posted January 13, 2021 Check this thread. Max Bore Size? - Banshee Repairs and Mods - Banshee HQ Forums My wifes drag ported OEM cylinders were @ 65mm - Had zero issues and still room to go if ever needed. *** By the way - This is the For Sale section not ISO/Wanted thread Quote
nastyracing Posted January 13, 2021 Report Posted January 13, 2021 I have a set shoot me a text 7329795230 Quote
