I have an older RAD nut. It is a single squeeze bolt system.
I've found that I still need to use the LocTite. BUT it is much easier to remove the nut when needed. Just loosen the squeeze bolt and then loosen the nut.
Cheers
Astromybud
i had one from hy tech atv, similar to the double lonestar, round with two allen pinchbolts.needed no loctite and never came loose.
I have one made by AlloySpecialties. I dont use loc-tite, just tighten up the 2 allen pinch bolts. I rode all spring, summer and fall with it and I needed to tighten it twice. I would get loose just enuf that my sprocket hub could move back and forth, id tighten up the axle nut and it would be good for 3 more months. It hasnt come loose since the last time I tighten it, about 2 months ago.
Dan from AS used to post here, but I havent seen him in along time.
