astromybud
Everything posted by astromybud
  1. I have a kit from ricky stator. mounts up front also. But had to make a small mode to mout a larger amphr battery. Just a small cut to allow for the extr length. Anyhow, you need more stator to run big lights. The battery only keeps the lights bright when your at an idle. You have to be able to put the juice back into the thing. If you just have the battery and not the high output stator your lights will still be dim. and then the battery will drain. Cheers Astromybud
  2. What do you mean by this? Are you going to take out your frustration on the quad? If so... Your a dick! And you got what you deserve. Of course if that's not what you mean.... My sincerest appoligies... Astromybud
  3. I have an older RAD nut. It is a single squeeze bolt system. I've found that I still need to use the LocTite. BUT it is much easier to remove the nut when needed. Just loosen the squeeze bolt and then loosen the nut. Cheers Astromybud
  4. Pull the choke! The power jet will only pull fuel around WOT. Make sure you have the metering rod set corectly also. I have a single 38/40 on mine and the starting point is 2" from tip of rod to the bottom of the slide. Set rod at a point that will allow the motor to start and idle. Then adjust rod until you get a good crisp throttle responce. After you get the idle and mid dialed in do you go to selecting you power jet size. If you need more tech info give fastbygast a call. They are super cool and will set you on the right track. Cheers Astromybud
  5. A man sellin his toys to get married!???? :shock: Dude you do that now and you will never get un-wrapped from her finger! Got to set the presidance now man........ Make her sell something! :wink: Cheers Astromybud P.S. I'll give you $2500.00 for it. "The Banshee"
  6. Since I have to do all the maint and buy the fuel and parts, Does my wifes count as two for me? :? Cheers Astromybud
  7. Tungsten, I would have to agree with you. Full bore, Fad! astromybud
  8. I found; My holeshots nobbies are alot like Good beer! Neither, sticks around for long! But I ride a lot of gravel roads!!!! 3"crush will cut up any tire.. Astromybud
