Schrader Posted April 13, 2020 Author Report Posted April 13, 2020 I got it from my neighbor he said he did a compression check when he first got it from an auction he said he had about 110-115 if I remember correctly. The fuel in my exhaust was from running it a while not from trying to start it it’ll start first few kicks it was running with the choke tube off I put it back on didn’t make a difference. I’ll go check out the reeds right now Quote
375hp banshees Posted April 13, 2020 Report Posted April 13, 2020 Either way , running it with a dead cylinder will still suck fuel in and flood itSent from my SM-A505U using Tapatalk Quote
Schrader Posted April 13, 2020 Author Report Posted April 13, 2020 I don’t think it’s flooded when I pulled the spark plugs I blew the cylinder out and let it dry for a good hour started up with a few kicks did the same thing. What should I do if you think it is flooded Quote
SKEETER Posted April 13, 2020 Report Posted April 13, 2020 Torch entire bike. Buy boat. Live happy. Quote
375hp banshees Posted April 16, 2020 Report Posted April 16, 2020 ^ Yeah all this info is no good, if you dont post results!Sent from my SM-A505U using Tapatalk Quote
Schrader Posted April 20, 2020 Author Report Posted April 20, 2020 No luck yet I think I’m going to go through everything one more time to make sure I didn’t miss anything then I might take it somewhere for some help but in the mean time of you guys think of anything let me know thanks Quote
Schrader Posted April 20, 2020 Author Report Posted April 20, 2020 I don’t know if I can put a video up but I have videos of before when it ran on both cylinders idling. Then after I cleaned the carbs idling on one cylinder it blows cold air but will blow blue smoke every once in a while not sure if seeing a video would help but lmk Quote
rkooienga Posted April 23, 2020 Report Posted April 23, 2020 I had the same problem with mine it's not flooded and it's not a spark issue is it? Been a minute since I had a banshee because mine was stilen. But forgive me if I'm wrong but Switch plug wires to make sure both wires fire. Then you have one of you carb slides in correctly and one in backwards. I did the same thing with my banshee when I rebuilt it. If you have the slides in backwards it wont start at all and with one in backwards the exhaust with be slightly warm and slightly blue due to only one cylinder firing. Check that next and let us know what happens. Also 105 is low my banshee blew up at 102 psi for compression. I bought mine with about 105 took it for one ride and snap one of the Piston rings on one cylinder. Quote
Schrader Posted April 27, 2020 Author Report Posted April 27, 2020 I think I may have figured it out I pulled the reeds out and the ends were frayed I’m going to put the stock ones in hopefully that’s the problem and it does make sense to me I’ll give you guys an update later Quote
Schrader Posted April 28, 2020 Author Report Posted April 28, 2020 Hey guys I got it it was the reed I had some after market vforce3s in and the right side was frayed at the end I put the stock ones back in and it was doing the same thing so I put new plugs in must have fouled the plug but it’s running good on both cylinders now thank you for your time and advice I hope this will help someone else out Quote
