What’s up guys I’m new here and pretty new to banshee’s... recently my 2003 has had some issues starting, i can kick it till the cows come home but unless I pull the clutch it won’t start. Any help is appreciated !!
Pull the clutch and kick at the same time... And it fires right up?
parking brake switch might be hooked up wrong. If It has a factory clutch perch, there's a two wire switch made into it
Sent from my XT1585 using Tapatalk
5 hours ago, ORBanshee said:
Well that's if your trying to start in gear, sorry just woke up and brain ajnt quite working yet, just realized your most likely in neutral sorry
Sent from my Pixel 3 using Tapatalk
It's okay you're from Oregon ...
we understand
  • 1 month later...
wtf, over..... this went nowhere fast.   waiting for the answer about letting the clutch out.  also, does it lunge foreward when you go into gear, but the clutch is pulled in?
