Everything posted by ORBanshee
What's done to your motor? Sent from my Pixel 3 using Tapatalk
Tedder, I sent you a pm, got a notification you responded, but Tapatalk shows I have no messages doesn't even show my sent message, are you on the HQ Fb and k could find you there? Sent from my Pixel 3 using Tapatalk
I don't mind building a new bike, it's just that for quite a while it would be a basically stock motor other than mods I could myself, I know some stuff about overrides, but what all actually goes into it? Is it something I'd be able to manage myself or need a shop to do? Sent from my Pixel 3 using Tapatalk
Mainly was worried because I had heard a few things about guys not getting enough flow and melting the motor down Sent from my Pixel 3 using Tapatalk
Also, would it be in my best interest to switch to a dual pingle? Running a standard OEM petcock currently and just replaced it so not too crazy about the idea of changing it again [emoji23] Sent from my Pixel 3 using Tapatalk
Not looking to be crazy competitive, just be able to still go out to the track and have a good time with my buddies while I rebuild my ranchero. No other qauds run out here so I'm not too worried about getting my as sbeat, just run some test and tune and see if maybe they'd just let me run in motorcycle bracket class or try and build interest and get more qauds out there. For 1/4 mile I'll probably need to change my gearing yeah? If interest starts to build up out there then I'll probably pick up another bike to be a dedicated drag bike Sent from my Pixel 3 using Tapatalk
Alright guys, been riding qauds for years, started racing at the track in my ranchero and my pick up about 2 years ago. Over here (southern Oregon) you never see qauds out running at the track (1 day a year). I recently picked up another banshee and I'm thinking about setting it up to run 1/4 mile here at my local track just to be different and have a good time. Bike is a duner and most of my riding is out in the Oregon dunes. It's a stock cyl ported 4 mill on race gas with a +4 swinger on the back, vforce 3, fmf turbinecore pipes, 34mm pj's. I'd like to keep running the bike as my main duner, so would it work out okay if I just picked up a set of tires for all the way around and changed gearing to run at the track? Or would I be better off picking up a different bike and starting from scratch? Thanks for your input y'all, I can do all the Fab work and motor work myself if I set up a new bike as well. Sent from my Pixel 3 using Tapatalk
Redline, my shit seems to like it the most, definitely likes redline more than it liked yamalube Sent from my Pixel 3 using Tapatalk
Westcoast Banshee in Indiana/Advice Requested
ORBanshee replied to Maui Jim's topic in Jetting & Exhaust Forum
From what I've heard t6's are more of a mid range pipe, personally I think it sound like your mains are really big but I'm not sure because my stuff has big carbs, if it was breaking up and falling on its face at high rpm, check your plug caps, the caps will unthread off the plug wires and then you can test them with an ohm meter, anywhere from 4.5-5 is good, if they come in any lower I'd replace them, mine was seriously falling on its face at high rpm, caps tested bad, replaced them and it runs like a top Sent from my Pixel 3 using Tapatalk -
You'd be surprised the power you get out of just pipes, you may not need to go 4 mill right off the bat and instead just do a nice set of pipes, and ported and polished. I agree suspension is a great place to start, having a fast bike is no good if it hurts you to ride it. On a final note, welcome to the HQ, as long as you can handle the occasion a$$hole, you'll be fine. Sent from my Pixel 3 using Tapatalk
I'm down in eagle point about 30 minutes from Medford Sent from my Pixel 3 using Tapatalk
Yeah he only ever rode Oregon dunes with it, bikes never saw dirt, he has the pair since new in 98. I'll get a tester on it and see what the results look like Sent from my Pixel 3 using Tapatalk
Also, riding at sea level at Oregon dunes, and occasionally mountains where I live which is ~1400 ft Sent from my Pixel 3 using Tapatalk
Hey all, just picked up another banshee, well, 2... One of them is a 4 mill with a dune port, he said he thinks it's 18cc domes(built the motor like 10 years ago) has 34mm keihin carbs, pro design coolhead,he ran a mix 50/50 110race fuel and 92 pump gas, we are wanting to run the bike on just pump gas, do we need to change up the dome size? Do we need to check compression in order to know if we need to change size? He said he's run it on straight pump gas before and that it seems to run fine just not as much power, thanks everyone, and a pic of the bikes for attention! The yellow is the 4 mill, blue bike is stock other than pipes and a boost bottle[emoji23] still has tors and all, it was his wife's bike. Also, what's the value on a set of blue fullbores in like brand new shape? They're flawless Sent from my Pixel 3 using Tapatalk
Pro circuit pipes to silencer clamp
ORBanshee replied to ORBanshee's topic in Jetting & Exhaust Forum
Yeah Cascade finally called back and mentioned the different size on the other end, I realized I'm a retard and it's been a long day[emoji23] installed and good now thanks y'all Sent from my Pixel 3 using Tapatalk -
Pro circuit platinum pipes, older style pro circuit 304 silencers, called Cascade they said they had clamps that fit even though they're not listed (part number exc-2) so they're for the toomy t4 pipes, just got them in the mail and they don't fit, the rubber with stretch enough to shove on but clamp is nowhere near fitting, anyone else have any experiences with this stuff? Tried calling them but no answer, trying to hit the coast for a week starting Monday and I guess I'm just gonna have to deal with my old torn rubbers that are dripping oil on my filters... Sent from my Pixel 3 using Tapatalk
Well I spent all night having bad dreams about my own problems so they were the only thing in my brain lol Sent from my Pixel 3 using Tapatalk
Well that's if your trying to start in gear, sorry just woke up and brain ajnt quite working yet, just realized your most likely in neutral sorry Sent from my Pixel 3 using Tapatalk
When the bike is not running, but in gear, can you pull the clutch in and roll it? Or does it still not want to roll even with the clutch in? Sent from my Pixel 3 using Tapatalk
Well the arrows are lined up so my guess is that it's time for a clutch? Sent from my Pixel 3 using Tapatalk
Good to know, thanks screamer, wasn't sure if they would have them since it's the older style, I think I remember reading somewhere that fmf packing is the best Stuff to use is that right? Sent from my Pixel 3 using Tapatalk
Probably be about 3 weeks before I get the chance, leaving for dunefest at the beginning of next week and today is basically my only work day on it because I'm swamped at actual work so that I can get the week of dunefest off Sent from my Pixel 3 using Tapatalk
So this is my first banshee, it has the older style pro circuit platinum pipes with the old style 304 silencers, replacing my rubbers where the pipe connects to the silencers because one side was dripping oil on my filters, that same side the silencer has some stuff on it up there(picture attached) and if I look inside the silencer the screen is broken and just plain trashed, I'm assuming I need to repack my silencers? Where can I find that screen like piece? Thanks guys Sent from my Pixel 3 using Tapatalk
I just bought it, where am I needed to line this up? If I just follow the cable down to the case will I find these arrows? Sent from my Pixel 3 using Tapatalk
Finally got a chance to take my Shee out for the first time, noticed during the trip that if I have my bike shut off and in gear, if I pull the clutch in I cannot roll the bike unless I put it in neutral, it won't move with the clutch in while in gear, it also when trying to start it in gear with the clutch in won't start and just tries to move, I have adjusted as much as I can up top at the lever, is there another adjustment down below? Or is it time for a clutch? Sent from my Pixel 3 using Tapatalk
