Missi0n02 Posted July 16, 2019 Report Posted July 16, 2019 What’s up guys I’m new here and pretty new to banshee’s... recently my 2003 has had some issues starting, i can kick it till the cows come home but unless I pull the clutch it won’t start. Any help is appreciated !! Quote
375hp banshees Posted July 16, 2019 Report Posted July 16, 2019 Pull the clutch and kick at the same time... And it fires right up? parking brake switch might be hooked up wrong. If It has a factory clutch perch, there's a two wire switch made into it Sent from my XT1585 using Tapatalk Quote
375hp banshees Posted July 16, 2019 Report Posted July 16, 2019 But if it's that, it'll die when you let clutch out while runningSent from my XT1585 using Tapatalk Quote
ORBanshee Posted July 16, 2019 Report Posted July 16, 2019 When the bike is not running, but in gear, can you pull the clutch in and roll it? Or does it still not want to roll even with the clutch in?Sent from my Pixel 3 using Tapatalk Quote
ORBanshee Posted July 16, 2019 Report Posted July 16, 2019 Well that's if your trying to start in gear, sorry just woke up and brain ajnt quite working yet, just realized your most likely in neutral sorrySent from my Pixel 3 using Tapatalk Quote
Missi0n02 Posted July 16, 2019 Author Report Posted July 16, 2019 Yes bike is in neutral but only starts when I pull in clutch Quote
375hp banshees Posted July 16, 2019 Report Posted July 16, 2019 Does it stay running when you let go of the clutch? Does it still have factory parking brake? Sent from my XT1585 using Tapatalk Quote
375hp banshees Posted July 16, 2019 Report Posted July 16, 2019 5 hours ago, ORBanshee said: Well that's if your trying to start in gear, sorry just woke up and brain ajnt quite working yet, just realized your most likely in neutral sorry Sent from my Pixel 3 using Tapatalk It's okay you're from Oregon ... we understand Quote
ORBanshee Posted July 16, 2019 Report Posted July 16, 2019 Well I spent all night having bad dreams about my own problems so they were the only thing in my brain lolSent from my Pixel 3 using Tapatalk Quote
SKEETER Posted July 16, 2019 Report Posted July 16, 2019 Fact. Nobody from Florida has shit to talk, about any orygun folk. Quote
AKheathen Posted August 21, 2019 Report Posted August 21, 2019 wtf, over..... this went nowhere fast. waiting for the answer about letting the clutch out. also, does it lunge foreward when you go into gear, but the clutch is pulled in? Quote
