lowkhalbalr Posted June 27, 2019 Report Posted June 27, 2019 Im looking for 15in tie rod tubes; anybody no where I can find some? Quote
97Screamer Posted June 27, 2019 Report Posted June 27, 2019 Fireball will make you any size you'd like. I usually buy longer oem ones off whatever and cut them to length. I run lsr yfzr tubes which are just over 14" so tubes for +1 yfzr should be close. You'll need 12mm ends to run yfzr tubes but with that wide if an arm you should have 12mm setup anyways.Sent from my HTC One M9 using Tapatalk Quote
trickedcarbine Posted June 29, 2019 Report Posted June 29, 2019 Fireball if you want it for trails or rec riding. Carbon Race Parts can hook you up if you need it light weight for racing. Quote
