Banshee27 Posted June 21, 2019 Report Posted June 21, 2019 Hey, I just replaced my head gasket like last week for the same reason, but a head stud broke. I had to wait for new ones to come in and now I fixed it. It makes a sound like pressure leaking from the exhaust or something when I try to start it up. Like a “tsch” should I replace the gasket again or is it probably something else. Rookie here by the way, so I just figured an air leak, but what do you guys think? Thanks for the help! Quote
gusto Posted June 21, 2019 Report Posted June 21, 2019 Spray the area with soapy water while someone’s kicking it over you might have lost a seal Quote
Banshee27 Posted June 21, 2019 Author Report Posted June 21, 2019 7 minutes ago, gusto said: Spray the area with soapy water while someone’s kicking it over you might have lost a seal I told someone to watch while I kicked and they said it seems like it’s coming out of the right exhaust pipe. I’ll spray the area too Quote
gusto Posted June 22, 2019 Report Posted June 22, 2019 Buy a new gaskets or o ring for your pipe and double check your head and intake isn’t leaking Quote
AKheathen Posted June 22, 2019 Report Posted June 22, 2019 make sure the pipe isnt full of coolant Quote
specialblend07 Posted June 24, 2019 Report Posted June 24, 2019 Could it be the exhaust spring hitting the pipe........ Quote
