martin059 Posted February 5, 2019 Author Report Posted February 5, 2019 Nice setup. A round carrier is the way to go. Envoyé de mon SM-G965W en utilisant Tapatalk Thanks man Sent from my iPhone using Tapatalk Quote
martin059 Posted March 1, 2019 Author Report Posted March 1, 2019 LITTLE LITTLE UPDATE I hate myself for not bagging my bolts and nuts I think there’s some missing. I Got board today so I’m starting to put some parts on that I have. I’m thinking of waiting and buying a bolt kit.. I’ve tried to explain the needs of the banshee to my wife. But she’s been really supportive about the situation so far...Anyways this project should be done by spring I hope. Sorry for the long drag. Tore it down last fall and this is my first build. It’s pretty pricey to try to get it all done by spring. Sent from my iPhone using Tapatalk Quote
trickedcarbine Posted March 1, 2019 Report Posted March 1, 2019 Definitely do a stainless bolt kit, but make sure to only run OEM or equivelant on the pivot bolt, A Arms, and shocks. Quote
martin059 Posted March 1, 2019 Author Report Posted March 1, 2019 Definitely do a stainless bolt kit, but make sure to only run OEM or equivelant on the pivot bolt, A Arms, and shocks. Yea thTs the best route for me thanks on the advice on the OEM bolts Sent from my iPhone using Tapatalk Quote
XXDEF1ANTXX Posted March 4, 2019 Report Posted March 4, 2019 On 3/1/2019 at 4:48 PM, martin059 said: Yea thTs the best route for me thanks on the advice on the OEM bolts Sent from my iPhone using Tapatalk The big spec bolt kits are nice. I just did the same thing as you did and the big kit came in handy. Buy some taps to clean out the threaded holes on the frame if you havent already. Even though all the holes were plugged when it was pcd I still needed to clean them out. It took about an hour but it was worth the time. You only need 3 tap sizes for the whole frame, one of them is just for the footpeg bolts. 1 Quote
martin059 Posted March 4, 2019 Author Report Posted March 4, 2019 7 is gay, go 10My next build will be for sure. Sent from my iPhone using Tapatalk Quote
Ayesully810 Posted March 4, 2019 Report Posted March 4, 2019 36 minutes ago, ClaudeMachining said: 7 is gay, go 10 so is spending 1000 dollars to replace a dented a arm haaaaaa 1 Quote
martin059 Posted March 4, 2019 Author Report Posted March 4, 2019 so is spending 1000 dollars to replace a dented a arm haaaaaaSent from my iPhone using Tapatalk Quote
ClaudeMachining Posted March 5, 2019 Report Posted March 5, 2019 so is spending 1000 dollars to replace a dented a arm haaaaaaIt's 350$ usd. Calm down young padawan.Envoyé de mon SM-G965W en utilisant Tapatalk Quote
martin059 Posted June 30, 2019 Author Report Posted June 30, 2019 Trying to make my front end straight Sent from my iPhone using Tapatalk Quote
mike0chek Posted July 2, 2019 Report Posted July 2, 2019 On 6/30/2019 at 6:13 PM, martin059 said: Trying to make my front end straight Sent from my iPhone using Tapatalk nice progress man, i recently installed the same suspension ur gonna like it Quote
martin059 Posted July 2, 2019 Author Report Posted July 2, 2019 Hell yeaMan have all the parts just need time off of work to complete the build Sent from my iPhone using Tapatalk 2 Quote
SandSlingerOR Posted July 3, 2019 Report Posted July 3, 2019 Snazzy looks great. Keep the pics coming 1 Quote
