Picking up my 7 mill motor from Driveline tomorrow.
martin059
If you had a little stock cylinder and complain that jetting two carbs is hard, maybe I’d agree. But that 7mm is so much motor, you’d be really holding it back with a 2/1. Twins will definitely be the way to go. 35’s will be the most reccomended, but if you do a lot of tight riding and need it to light right away you can try a set of 33’s.
  • Like 1
Id wonder how a set of 28s would do. no that I plan on running them, but I bet you could trail it better with 28s, I did stockers on a 4 i think 28s on a 7 would be do able without choking it too much.
