if the gas has ethanol then it is most likely causing it.  ethanol is prolly burning the raw brass of the jet.
I dont know when it started tuning color. same gas station,same oil as i always use
Been using these jet awhile now 270s
It started randomly stalling when i first start it an go to take off wouldnt want to start back up unless i drained my bowls out and it ran fine after that so i took the carbs apart and this is what i find on the choke side carb the other side looks nice an clean
I cleaned them out an it seems fine now
Just wondering what is causing it to turn black
15 minutes ago, kawa110 said:
Oil separating from fuel and sinking to bottom?
that was my first thought but doesnt oil (benol and stuff like that) only separate in cold temps?
  • 2 weeks later...
can you run stock stroke with 115mm rods with 795 pistons with stock head An no spacer plate???
Gunna redo my motor this winter
and dont want to stroker it  but would like to got 115 long rods
