Can you port cheap $100 ebay jugs? Prob is my sticker are at 64.45 (piston).. not worth paying for a port job if this rebuild I will be at 66mm. Right? Jugs are done need resleved.. how much does it usually cost to resleve?
Buy smaller bore stock jugs and  have them bored and ported. I agree with you its a waste to port 66mm cylinders but its also a waste to port junk cylinders. For around $100 you should be able to find an oem set that need a bore.
4 hours ago, Damann said:
Has anyone ever ran cheap Namura piston kit? What is to expect? How long of life? What compression?
Running the cheap jugs is fine assuming you're lucky enough to get a set where the head studs line up and the two cylinders are level enough you can get the head/base to seal. Don't run the cheap pistons, not worth it. When (not if) they go you're risking your good crank, cases, stator etc... I have a left stock bore oem jug if you can find a right lol. I see sets needing a bore selling every week on Fb, just gotta jump on them when you see a deal or someone else will.
Awesome, good to hear. I figured I'd get bottom end with new crank sealed and be piston shopping. Save the cheapies jugs/pistons for a quick fix n flip bike. So shelf the  Namura kit it is. Thanks
it took me a over year to sell a set of stockers that I bored to new pistons and cleaned up the porting for $200. The junk ass Chinese cylinders that come with stripped holes, unlevel ports, unchamfered ports, soft ass steel sleeve have ruined the market.
What do you mean? Cheap jugs are better then OEM or can be? Do you think cheap $100 ebay jugs and piston can hold up to basic mods and last as long as an OEM jug? I don't think a pro bike builder would even port an ebay cylinder, correct me if I'm wrong? I have both and would like to use the cheap set one day for something
You said : Metal was better in older car.
I said : Not at all.
