Ride2fast Posted March 22, 2018 Report Posted March 22, 2018 (edited) My wheeler is cutting out at quarter throttle to half right before power band it’s like it hesitate for a second to kick into power band what could this be my jets was going to order a jet kit It’s stock motor when FMF pipes all the way back stock jets in carbs Edited March 22, 2018 by Ride2fast Quote
ride.race.live Posted March 22, 2018 Report Posted March 22, 2018 well for starters could be lean with pipes.... you more then likely need at the least 27.5 pilots when did this issue start ? did it just start doing it after installing pipes or did it start randomly out of no where and no changes where made Quote
Ayesully810 Posted March 22, 2018 Report Posted March 22, 2018 (edited) id be more concerned with the 200 main jet. Most stock piped bikes will take a 25 pilot as long as your not riding in the winter or late fall Edited March 22, 2018 by Ayesully810 Quote
hoppedupandcutdown Posted March 23, 2018 Report Posted March 23, 2018 Check size of both jets and report back. Include type of air filter, with or without air box, and/or lid. Quote
Toybreaker Posted March 23, 2018 Report Posted March 23, 2018 mix ratio can have an effect on jetting too...... 1 Quote
Ride2fast Posted April 11, 2018 Author Report Posted April 11, 2018 All right to answer some of your guys questions the wheeler is all tore apart now had frame painted but when I got it it had the pipes on it but was not running right so I put it back down to the stock Jets And started running better but did that hesitation thing right before power band so all the Jets are stock with FMF pipes all the way back and I mix 32 to 1 Quote
fckawhipboughtabanshee Posted April 11, 2018 Report Posted April 11, 2018 (edited) Same thing was happening to mine before my crank gave out but was able to ride it for another 2 to 3 weeks before it blew , would ride good until tryna gas it than it was bog n pull bog n pull still accelerating but hesitant the whole time on the power band Edited April 11, 2018 by fckawhipboughtabanshee Quote
Toybreaker Posted April 11, 2018 Report Posted April 11, 2018 13 hours ago, Ride2fast said: All right to answer some of your guys questions the wheeler is all tore apart now had frame painted but when I got it it had the pipes on it but was not running right so I put it back down to the stock Jets And started running better but did that hesitation thing right before power band so all the Jets are stock with FMF pipes all the way back and I mix 32 to 1 stock jets are WAY TOO LEAN for those pipes. 280-300 mains 27.5 pilot and the stock needle in the middle. (stock carbs) if you haven't hurt it yet, that will get you in the ball park Quote
Ride2fast Posted April 11, 2018 Author Report Posted April 11, 2018 Yes they’re stacked carbs and I hope I didn’t hurt it it ran good when I parked it besides that I’m going to order a jet kit And try that once I get it back together I figured it was just the Jets I didn’t drive it a whole lot like that maybe eight hours Quote
Ride2fast Posted April 12, 2018 Author Report Posted April 12, 2018 and I have the airbox lid on with holes in it air filter is some generic kind I can’t remember the name stock jets stock carbs everything on the motor is stock besides the exhaust so I’m going to get a jet kit and play around So what would be the best sizes to start with with FMF pipes all the way back Quote
Ride2fast Posted April 12, 2018 Author Report Posted April 12, 2018 id be more concerned with the 200 main jet. Most stock piped bikes will take a 25 pilot as long as your not riding in the winter or late fallSo what size should I start with with all fmf pipes Sent from my iPhone using Tapatalk Quote
Ride2fast Posted April 12, 2018 Author Report Posted April 12, 2018 stock jets are WAY TOO LEAN for those pipes. 280-300 mains 27.5 pilot and the stock needle in the middle. (stock carbs) if you haven't hurt it yet, that will get you in the ball parkSo I should start with a 280 main Sent from my iPhone using Tapatalk Quote
Ride2fast Posted April 12, 2018 Author Report Posted April 12, 2018 So I should start with a 280 main Sent from my iPhone using Tapatalk should I get this and start with smallest size Sent from my iPhone using Tapatalk Quote
bansheesandrider Posted April 12, 2018 Report Posted April 12, 2018 15 minutes with that jetting could have hurt the engine. When I had 2 bikes with FMFs, the jetting was 280 or 290 main, 27.5 pilot, clip in the middle of the stock needle. when jetting, you should always start rich and work towards lean- start with a big number and go smaller 1 size at a time. 1 Quote
Toybreaker Posted April 12, 2018 Report Posted April 12, 2018 My shee has been all over the stock cylinder, stock stroke spectrum. with basic bolt ons from sea level to about 1000 feet mixing 32:1 280 mains ran the best with the FMF pipes. it ran ok up to 310 main, but ALWAYS ran best with a 27.5 pilot. toomey needle liked 1 notch closer to the tip and the stock needle liked the center notch. Start with the 300 main and do a plug chop. start fat it doesn't hurt.... 1 Quote
