Hey everyone!
It has been a while, starting a company is a lot of work. I am back and need your expertise.
Back in December I posted a thread called "How Do I Fix This?"
Basically I accidentally got a stroker rod and my pistons are sticking out of the cylinder 5mm at top dead center.
So a user told me to get Wiseco 795 series pistons and that will solve this problem.
My next question is; do I need a spacer for this build? I read around a bit and I am getting mixed reviews.
I really appreciate you guys and all of your help! I reply fast, so if you have any questions, ask away!
13 minutes ago, n2otoofast4u said:
What is the number on the rod? What stroke is the crank?
Sent from my SM-G930V using Tapatalk
The engine is currently put together, and I don't remember any numbers on the rod itself, although I remember two words like long rod or something like that on the rod.
If its really necessary I can split the cases and I will pull the cylinders off and report back, if I can avoid splitting the cases I want to.
Edited by Banshee2105
Clarification
1 minute ago, trickedcarbine said:
110mm rod is standard. 115 rod will require 795.
So I just need the 795 pistons? My stock replacement pistons stick out 5mm so that makes sense. And no spacer needed, is that correct?
