I just recently bought a 2005 banshee and it had the tors delete already done. But whoever did it never drilled,  tapped and installed the idle screws the hole is just filled with silicone. Would you guys happen to know why this would have been done. I know it's not right but just curious as to why it would have been done and will it hurt anything if it stays like that.
I'll try to get some pics this afternoon. The spare parts he gave me it had the idle screws in there but they weren't installed. I will have to pull the carbs off and see what I can see but is it necessary to install the idle screws.
Some lazy people just adjust the cable on the top of the carb to sync and set the idle.
i did that on my stockers.  didnt trust myself drilling lol
  • 3 weeks later...
Found out why the holes were siliconed. I got the carbs off and removed the silicone from the idle screw holes and both holes have a broken tap in them. I took it to work and got the taps out with a carbide endmill and re tapped the holes but the holes are waddled out and the screws are extremely loose. Would it hurt to drill the hole oversized and press in a plug and redrill and tap or should I just look for a new carb body.
