jetfighter120 Posted October 7, 2017 Report Posted October 7, 2017 I have a 392 big bore dual 28mm keihin carbs and fmf pipes also tors unplugged I tried all kinds of jet and needles. It revs high but dosnt go all the way into powerband im stumped Sent from my VS988 using Tapatalk Quote
hotrod9193 Posted October 7, 2017 Report Posted October 7, 2017 I have a 392 big bore dual 28mm keihin carbs and fmf pipes also tors unplugged I tried all kinds of jet and needles. It revs high but dosnt go all the way into powerband im stumped Sent from my VS988 using Tapatalk Have you plug chopped to make sure your jetting is Right? Sent from my SM-G930R4 using Tapatalk Quote
jetfighter120 Posted October 7, 2017 Author Report Posted October 7, 2017 No but i tried going up and down on mains and different. Needles but ill try thatSent from my VS988 using Tapatalk Quote
hotrod9193 Posted October 7, 2017 Report Posted October 7, 2017 You need to do a plug chop. It sucks wasting money on plugs but it's well worth it in the long run. Look up how to do a plug chop. Do one and let us know. Also if you have the stuff to do so do a compression test and a leak down test Sent from my SM-G930R4 using Tapatalk Quote
2004LEBanshee Posted October 7, 2017 Report Posted October 7, 2017 Im not understanding how it revs high but not hitting a powerband. Did you just assemble this? What electrical system you running and is your pickup gaped right? Quote
jetfighter120 Posted October 7, 2017 Author Report Posted October 7, 2017 I had a shop build it its the stock eletrical with tors taken off so i dont know what that gap is like, do you need to remove the fly wheel??Sent from my VS988 using Tapatalk Quote
salmon_slayer06 Posted October 7, 2017 Report Posted October 7, 2017 You want the gap as close as possible without touching the raised tabs on flywheel. Check grounds. After a long ride I check plugs once cooled down some, I use that electrical contact cleaner and spray out plug boots as black residue builds up, and twist boots on just a little tighter to assure good connection. Could it possibly be a faulty cdi? Try getting a used one for backup anyway. Something wrong with reeds? Quote
jetfighter120 Posted October 7, 2017 Author Report Posted October 7, 2017 The gap is good Sent from my VS988 using Tapatalk Quote
gusto Posted October 7, 2017 Report Posted October 7, 2017 If it's not the carbs try cutting back your plug wires next. Then try swapping out your cdi and ohm your stator. SouthTexasBanshee YouTube page goes through the testing. Quote
jetfighter120 Posted October 7, 2017 Author Report Posted October 7, 2017 I just noticed when i pull the chokes out it idles extremely highSent from my VS988 using Tapatalk Quote
jetfighter120 Posted October 7, 2017 Author Report Posted October 7, 2017 Could my timing be offSent from my VS988 using Tapatalk Quote
gusto Posted October 7, 2017 Report Posted October 7, 2017 Cub cylinders? ported? Have you set your floats right? Have you cleaned your slides needles and jets? Quote
gusto Posted October 7, 2017 Report Posted October 7, 2017 What's timing set to? I doubt it though. Quote
jetfighter120 Posted October 7, 2017 Author Report Posted October 7, 2017 Athena and no porting they are clean. How do you set floats on a 28 pwk and i had a shop do it so i dont know what the timings set apSent from my VS988 using Tapatalk Quote
gusto Posted October 7, 2017 Report Posted October 7, 2017 i don't know anything about those cylinders. You should check for an air leak, so leakdown test your engine. You can check if your gas lines and tank filter is clogged. you can ohm out your electrical. also look at the jetting thread on this forum, see who's running a set up close to yours and try what jetting they're using. that should keep you busy for the weekend Quote
