themechanic Posted October 13, 2017 Report Posted October 13, 2017 Sounds like carb issue if you pull the choke and it doesn’t riches up, just curious what pilots and mains are you running?Sent from my iPad using Tapatalk Quote
jetfighter120 Posted October 14, 2017 Author Report Posted October 14, 2017 155 mains 45 pilots now one side fires other dosnt got a new coil my stators goodSent from my VS988 using Tapatalk Quote
jetfighter120 Posted October 14, 2017 Author Report Posted October 14, 2017 Floats are rightSent from my VS988 using Tapatalk Quote
sleeper06 Posted October 15, 2017 Report Posted October 15, 2017 If spark is good, have you done a pressure test n compression test. If so did it hold air . What compression reading and what fuel. 28s I've seen jetting all over the place . I did a ported bike that liked 145s, and a different one like 170s . Both liked the jjh. I've seen stockers like 150s and 160s with a Lil compression . What it feel like blubbery or hollow Quote
themechanic Posted October 15, 2017 Report Posted October 15, 2017 I’m thinking you got a nice air leak somewhere Sent from my iPhone using Tapatalk Quote
jetfighter120 Posted October 15, 2017 Author Report Posted October 15, 2017 I just took the head off there was a coolant leak going into the cylindersSent from my VS988 using Tapatalk Quote
jetfighter120 Posted October 15, 2017 Author Report Posted October 15, 2017 Its at 150 psiSent from my VS988 using Tapatalk Quote
jetfighter120 Posted October 17, 2017 Author Report Posted October 17, 2017 Fixed the leak and shee zooms thanks for the info and help Sent from my VS988 using Tapatalk 1 Quote
JUSTWANNARACE Posted October 18, 2017 Report Posted October 18, 2017 On Saturday, October 07, 2017 at 11:22 AM, gusto said: i don't know anything about those cylinders. You should check for an air leak, so leakdown test your engine. You can check if your gas lines and tank filter is clogged. you can ohm out your electrical. also look at the jetting thread on this forum, see who's running a set up close to yours and try what jetting they're using. that should keep you busy for the weekend Driveline and athena are the same casting. DL are just machined for different port heights. Quote
Ayesully810 Posted October 18, 2017 Report Posted October 18, 2017 aren't DLs nickasil plated and athenas aren't? Quote
gusto Posted October 18, 2017 Report Posted October 18, 2017 Athenas are but i always heard they were really cheaply plated and had high port timings which made them hard to set up and get usable power. Quote
