jetfighter120
Everything posted by jetfighter120
  1. Fixed the leak and shee zooms thanks for the info and help [emoji13][emoji3][emoji3][emoji3][emoji3][emoji3][emoji3][emoji3][emoji3][emoji3][emoji3][emoji3][emoji3][emoji3][emoji3][emoji3][emoji3][emoji3][emoji3] Sent from my VS988 using Tapatalk
  2. Its at 150 psi Sent from my VS988 using Tapatalk
  3. I just took the head off there was a coolant leak going into the cylinders Sent from my VS988 using Tapatalk
  4. Floats are right Sent from my VS988 using Tapatalk
  5. 155 mains 45 pilots now one side fires other dosnt got a new coil my stators good Sent from my VS988 using Tapatalk
  6. Athena and no porting they are clean. How do you set floats on a 28 pwk and i had a shop do it so i dont know what the timings set ap Sent from my VS988 using Tapatalk
  7. Could my timing be off Sent from my VS988 using Tapatalk
  8. I just noticed when i pull the chokes out it idles extremely high Sent from my VS988 using Tapatalk
  9. The gap is good Sent from my VS988 using Tapatalk
  10. I had a shop build it its the stock eletrical with tors taken off so i dont know what that gap is like, do you need to remove the fly wheel?? Sent from my VS988 using Tapatalk
  11. No but i tried going up and down on mains and different. Needles but ill try that Sent from my VS988 using Tapatalk
  12. I have a 392 big bore dual 28mm keihin carbs and fmf pipes also tors unplugged I tried all kinds of jet and needles. It revs high but dosnt go all the way into powerband im stumped Sent from my VS988 using Tapatalk
