How does a cable over come the mechanical limit of the thumb throttle? It is not a problem with the cable. It is not a problem with the adjuster on top the carb's cap.
I'm sure he did. I have the same thing. But that is irrelevant. Check to make sure they fully open with what ever thumb throttle you are using.
Some modding to housing is needed on case to case basis but with the different cable it's much easier. The stock motion pro cable is a bitch to get WO . At some point motion pro changed there production site if I remember correctly there were certain part numbers that work and the newer ones don't .  So usually I call motion pro and they make me 10 at a clip . I know cam does the same , just bigger quantities
22 hours ago, RagunCajun said:
Make sure your thumb throttle fully open's those big carbs too. My stock one didnt until i modded it. Honda's ones cant without modding/epoxy. ( At least on my bike with 39's )
21 hours ago, locogato11283 said:
Redline has the cables for that. He will set them up.
11 hours ago, locogato11283 said:
Because Redline got with Motion Pro and got the specs right. Done and done.
That has nothing to do with what i said.
