[email protected] Posted July 2, 2017 Report Posted July 2, 2017 About 2 days ago I bought a shifter kart with banshee motor and I'm curious what does this blue tube do? What is the purpose And it's only on one side of the cylinder It has t-rax cylinders but I can't find any information about themIf anyone knows something about them please let me know Sent from my iPhone using Tapatalk Quote
[email protected] Posted July 2, 2017 Author Report Posted July 2, 2017 I thought so too since it's connected to what it looks like a fuel pumpSent from my iPhone using Tapatalk Quote
[email protected] Posted July 2, 2017 Author Report Posted July 2, 2017 But for some reason it's squirting fuel from carbs from overflow tubes when that thing is running and I don't know why...Could it be that the fuel pump is too powerful?Sent from my iPhone using Tapatalk Quote
trickedcarbine Posted July 2, 2017 Report Posted July 2, 2017 Possible they have a fuel pump on non pumper style carbs. It's more likely that it's just the float adjustment. Are both carbs spitting the same amount? Quote
[email protected] Posted July 2, 2017 Author Report Posted July 2, 2017 I'm not sure about that but they are keihinsAnd they are spitting from both sidesSent from my iPhone using Tapatalk Quote
trickedcarbine Posted July 2, 2017 Report Posted July 2, 2017 From what I can find, the part number on there indicates a regular 35mm PWK. If they haven't been converted to pumper style, you will need to have that done or purchase different carbs. Quote
Keno Posted July 2, 2017 Report Posted July 2, 2017 Those look to be 35mm carbs. (I believe only snowmobile 39mm came with pumper n/s) Open up the bowl and see if the needle and seat have been changed for a fuel pump. Quote
[email protected] Posted July 2, 2017 Author Report Posted July 2, 2017 Just checked the carbs and they appear to be untouched internally Sent from my iPhone using Tapatalk Quote
[email protected] Posted July 2, 2017 Author Report Posted July 2, 2017 Can I mod these carbs and make them work with my setupSent from my iPhone using Tapatalk Quote
n2otoofast4u Posted July 2, 2017 Report Posted July 2, 2017 Why?Sent from my SAMSUNG-SM-G891A using Tapatalk Quote
[email protected] Posted July 2, 2017 Author Report Posted July 2, 2017 My goal is to stop fuel from overflowing from carbs that are pump fed Sent from my iPhone using Tapatalk Quote
trickedcarbine Posted July 2, 2017 Report Posted July 2, 2017 Yes they should be able to be set up for use with the pump. Look in to having it done by someone who is familiar with converting carbs to alky use. Quote
Keno Posted July 2, 2017 Report Posted July 2, 2017 (edited) Redline will do the conversion for $100/pair Edited July 2, 2017 by Keno added link Quote
[email protected] Posted July 2, 2017 Author Report Posted July 2, 2017 Will give redline a call on Monday Just what I needed Thankyou Sent from my iPhone using Tapatalk Quote
