jeremyshee01 Posted June 6, 2017 Report Posted June 6, 2017 My question is just as it reads, what do u guys think a cool head should be torque to? Sent from my SCH-I535 using Tapatalk Quote
PaymentPlan Posted June 6, 2017 Report Posted June 6, 2017 My question is just as it reads, what do u guys think a cool head should be torque to? Sent from my SCH-I535 using Tapatalk Clymer manual specs. The same as OE. Sent from my SM-G900V using Tapatalk Quote
Ducman Posted June 6, 2017 Report Posted June 6, 2017 Same torque sequence as stock, criss cross the middle then the outer nuts. Torque in sequence to 10 lbs, then 15, then 20 Ft-lbs. I usually go back through the pattern 2x on the last torque to make sure they're all at 20 Ft-lbs. Quote
jeremyshee01 Posted June 6, 2017 Author Report Posted June 6, 2017 Thanks guys, that is what I was thinking, just want sure if 20 was sufficient with a higher hp shee. After what is to me an ungodly amount of money sunk into this thing I find myself double guessing things and stressing out a shit ton lol. Sent from my SCH-I535 using Tapatalk Quote
Keno Posted June 7, 2017 Report Posted June 7, 2017 Thanks guys, that is what I was thinking, just want sure if 20 was sufficient with a higher hp shee. After what is to me an ungodly amount of money sunk into this thing I find myself double guessing things and stressing out a shit ton lol. Sent from my SCH-I535 using Tapatalk An M8 bolt tightened to 20ft-lbs applies around 5000lbs of clamping force. This should make you feel better. 1 Quote
