I have been bleeding my brakes for 2 days now and can't seem to get any pressure
Any suggestions
Replace parts. Lol!
  • Like 1
Yeah man I recommend you get a cheap vacuum pump from harbor freight makes a world of difference, you put the hose on the bleeder screw ,pump the vacuum pump until it creates a vacuum, then you crack the bleeder screw loose keep an eye on the master cylinder do not let it suck the brake fluid all the way down keep topping it off do this a couple times on each side you could literally watch the air bubbles come out
Suck on the hose attached to the caliper till you see or taste fluid.
Don't swallow this time.
  • Like 4
any pump what am I looking for
If you want, over night zip tie lever to bar. I heard this work.
Then tomorrow go to HF and get the bleeder pump. You'll be done in 3 minutes
Sent from my SAMSUNG-SM-G890A using Tapatalk
do I leave the bleeder screws open or both closed
open
  • Like 1
