ckylesworld1 Posted April 27, 2017 Report Posted April 27, 2017 I just bought a 99 banshee yesterday. Its stock except fmf pipes/silencers and k & n filter. He said he uses klotz benol in it and gave me a gallon of it. I have never used it before and it has a pretty strong smell. Is this good oil for a stock banshee or is there something better I should buy. He also said it is running on non ethanol gas. I love the smell of race gas so when it is due for a fill up i intend to get some of it. What oil would work good with that kind of gas? I havent had a banshee in 10 years so seems like i forgot everything lol thanks Quote
Motooutcastxxx Posted April 27, 2017 Report Posted April 27, 2017 (edited) If it's not set up to run race fuel DO NOT use it... I ran Benol in my stock stroke stock crank ported motor, no issues. Edited April 27, 2017 by Motooutcastxxx Quote
ckylesworld1 Posted April 27, 2017 Author Report Posted April 27, 2017 (edited) ok, thank you. Edited April 27, 2017 by ckylesworld1 Quote
spurdy Posted April 27, 2017 Report Posted April 27, 2017 Benol is fine. Race rule will not hurt anything even if it isn't set up for it. There is just no reason to run a higher octane fuel unless your compression ration requires it. Sent from my iPhone using Tapatalk Quote
ckylesworld1 Posted April 27, 2017 Author Report Posted April 27, 2017 great info guys. Thank you. Quote
ClaudeMachining Posted April 27, 2017 Report Posted April 27, 2017 Benol is fine. Race rule will not hurt anything even if it isn't set up for it. There is just no reason to run a higher octane fuel unless your compression ration requires it. Sent from my iPhone using Tapatalk Are you sure about that?? Quote
spurdy Posted April 27, 2017 Report Posted April 27, 2017 Are you sure about that?? Yes. Higher octane fuel is needed for high compression engines to prevent detonation. If you run high octane fuel in a lower compression engine there is no harm except to your wallet. But I'd love to hear something logical that contradicts my statement. Sent from my iPhone using Tapatalk 1 Quote
ckylesworld1 Posted April 27, 2017 Author Report Posted April 27, 2017 I called the local gas station and it sells 104 octane. I ran it in my previous 01 stock banshee 10 yrs ago and it seemed ok but I only had it a year. Quote
ClaudeMachining Posted April 27, 2017 Report Posted April 27, 2017 Yes. Higher octane fuel is needed for high compression engines to prevent detonation. If you run high octane fuel in a lower compression engine there is no harm except to your wallet. But I'd love to hear something logical that contradicts my statement. Sent from my iPhone using Tapatalk In any given engine,same setup, do you think the fuel will explode at the same time 110 vs 92?? Quote
spurdy Posted April 27, 2017 Report Posted April 27, 2017 110 will resist premature ignition where as 92 will have less resistance. Doesn't mean that they won't ignite at the same time in a specific application (low compression engine with ignition taking place appropriately when the spark plug sparks). However, increase compression and 92 will begin to prematurely ignite before 110 will. Continue to raise compression and 110 will prematurely ignite as well. Sent from my iPhone using Tapatalk Quote
Keno Posted April 27, 2017 Report Posted April 27, 2017 In any given engine,same setup, do you think the fuel will explode at the same time 110 vs 92??It shouldn't be exploding in either engine. It should be igniting. All things the same, an engine built for 92 octane will possibly make less power with race fuel do to reduced combustion temps and possible incomplete ignition. Quote
ClaudeMachining Posted April 27, 2017 Report Posted April 27, 2017 It shouldn't be exploding in either engine. It should be igniting. All things the same, an engine built for 92 octane will possibly make less power with race fuel do to reduced combustion temps and possible incomplete ignition. Because French. I'm just thinking out loud, i'm not debating anything. Quote
spurdy Posted April 27, 2017 Report Posted April 27, 2017 Nice having a discussion with curse words and being called an idiot, isnt it? Must be the first time on here Yay! Lol! Nothing wrong with thinking out loud and using a little logic to draw a conclusion. All I was saying is that you won't damage anything by running a fuel with a higher octane rating. It may not operate at peak performance, but no damage should occur. Sent from my iPhone using Tapatalk Quote
