Hey guys,
Banshee 2007
380cc
V force 3
Toomey T5
Main 320
Pilot 27.5
Ok... I'm kind of lost on this. I'll put you in context. When I bought my banshee 2 month ago I tested/ran it at the seller and when I was home without any issue. Everything run great but see little hesitation at low torque and I know it can be better. So I decide to put it a part, put entire bike new bushimg and bearing and rebuilt carb ( at the same time fix the little leak from the bowl hose too) when I put it back together I`m still have a little leak from the right carb (was rebuilted with a shindy rebuilt kit and float height adjusted at 20.5-21) very little leak but nothing the other side! Normal?
And when i ride it hard this morning gearbox oil was spitting big time by the vent hose.
Keep in mind that no hose was pinched or clogged. It happened twice and make the tube longer to prevent to have my leg soak of oil.
Wtf?
Hhheelllpppppp!
Thanks
-Steve-
I heard that banshee with mods will spit gearbox oil because motor spin faster than normal? I don't beleve in this...
I don't perform a leak test because I don't have the gage. But what can presurize the gearbox case without the crank seal?
And the gearbox oil was set to 1400ml for make sure it's not overfilled... that was my first thinking!
The only mod I made that touch the gearbox it's a moose case saver and I change the rubber seal behind the white plastic parts for make sure I have no leak! Maybe it vome from there?
Why it was not doing this when I try it just before bought it! It begin just after I put it a parts... and I'm sure that no hose are pinched or clogged... the only work I perform was new coil, cap and plug, rebuilt carb, moose case saver, oversized rad and some bushing and bearing..
Ok guys...
Just made some test,
Vent from waterpump case: free air passing with oil bubble (oil cap open or not)
Vent from the back:
Free air passing when oil cap is remove and when cap is srewed tight, not! Pressure is made.
WTF?
Make no sense...
What kind of oil are you using?
When I bought it was klotz.I change the oil and be sure level is ok with motul ester. With both oil it spit from the vent.
Spit around 500ml in less than 1km but full trottle.
