cmyyard19 Posted December 6, 2003 Report Posted December 6, 2003 I just installed a trinity cv 35mm carb set up on my shee and it wont idle, as soon as I let off the gas, it shuts off. What do I need do? Thanks Quote
Klotz Posted December 6, 2003 Report Posted December 6, 2003 kick her over...let it run then play with it....there is no certain amount...just until you get it where you want it...thats all you have to do..simple as that shane Quote
cmyyard19 Posted December 6, 2003 Author Report Posted December 6, 2003 I started all the way out and very slowly turned it all the way in and it still wouldn't idle but it was almost idling when it was all the way in. I noticed a lot of oil come from my pipes, so I checked the spark plugs and there definitely oil fouled. I'm running 4 oz per a gallon so I guess I will mix up some new gas and cut back to 3 oz per a gallon. Could this part of my problem? Quote
Proquad101 Posted December 7, 2003 Report Posted December 7, 2003 It sounds to me like you need to adjust your jetting not your fuel oil mixture. What jets are you runing now? Quote
2banshees Posted December 7, 2003 Report Posted December 7, 2003 did you unhook the tors control box? its under the gas tank. unplug it first. then look elseware. Quote
cmyyard19 Posted December 7, 2003 Author Report Posted December 7, 2003 I just bought it, so I really don't know what the jetting is but I will try and look it up. The tors are completely removed, am I supposed to do anything with the wires? Quote
