I have a gorgeous MX race ready banshee for sale. The quad is in like new condition, I drive it about 3 times a year and is stored in my heated work shop. The bike is completely custom built, the frame is a 1998 all the rest of the parts where purchased from 2002 to 2003. The bike cost almost 12k in parts alone to build.
Go to
http://www.geocities.com/dover_19/mxbanshee.html
for picture and to
http://video.google.com/videoplay?docid=-3670266633651935719
for a little video clip.
98 engine $1000
The entire engine was rebuilt by "Dan the man" Patriot Racing, WA with 370cc cylinders MX ported, Upper case ported to match cylinders $1795
Full description of motor build can be see at http://www.patriotracing.net/Banshee%20350%20MX.htm
TRD trued and welded long-rod 5mm w/ 10 balled bearings $510
Wiseco Long Rod pistons
D&D billet head 170psi compression
Janssen +2" up 1" A-arms $670
Axis shocks w/ rezzies $1275
Ricky stator Tie rods $200
V Force Delta Reeds
Pro design dual carb intake w/ boost bottle $229
28mm carbs
Full bore plastics Front $315
Full bore plastics Rear $264
Lonestar "Axcaliber" axle $410
LoneStar Swing arm $827
"Dyna" digital adjustible ignition $300
Stator from Ricky Stator $185
YZ clutch fibers and springs $125
Modified shift star $40
EBC brake pads $25
AMP LINK $119
DID chain $65
Paul turner Low/Mid pipes $379
Fat boy aluminum silencers $219
PRM "baja" front bumper $90
PRM rear grab bar $60
DG "baja" full skid plate $109
AC swing arm skid plate $105
DG nurf bars $150
Fly clutch lever $50
Billet Axle nut $40
Chrome Kit:
Rear brake lever $60
Master cylinder cover $20
Throttle cover $25
Kick Starter $50
Foot Pegs $100
Exhaust hangers $40
Renthal Bars $60
spider grips $20
Tether kill switch $34
98 Frame $300
Frame Professionally painted $200
Front MX racing grooved tires $140
Mounted on Douglas black label wheels w/ racing rings $200
Front Maxxis Razr tires $140
Maxxis Razr rears $140
on Douglas Red label wheels $120
Maxxis MX razor rears $140
Mounted on Douglas Black Label wheels w/ race rings $200
Stock banshee parts: Headlights, radiator, wiring
