4mill build
SlowMoe
I bought this banshee a couple months ago. Nice clean roller with a set of sand and dirt tires. T5's 34mm carbs and a complete motor minus Pistons.
So I sold the crank jugs and pipes so I could upgrade to a 4 mill crank, do some porting and get some better pipes.
I should be getting my crank Pistons and jugs in the mail tommorow, so I am starting to clean up the cases and put the tranny in currently. Pics
e14a1d4441fb2bdcd988605da28f1529.jpg1723da22b23fdc7235d2326ef0f924ca.jpgdb12f3d2e6a957ec3a459e0fe64b8bc7.jpg
Old gasket residue on cases
000fa36f75451225d4b1bf466c60563a.jpg6c637a430c4d2ed1e570fcb588fc4a5b.jpg9a6db97fad6f79375606052b7133350f.jpg
Mating surfaces cleaned up with scotch brite
I should be getting my crank Pistons and jugs in the mail tommorow, so I am starting to clean up the cases and put the tranny in currently. Picse14a1d4441fb2bdcd988605da28f1529.jpg1723da22b23fdc7235d2326ef0f924ca.jpgdb12f3d2e6a957ec3a459e0fe64b8bc7.jpg
Old gasket residue on cases000fa36f75451225d4b1bf466c60563a.jpg6c637a430c4d2ed1e570fcb588fc4a5b.jpg9a6db97fad6f79375606052b7133350f.jpg
Mating surfaces cleaned up with scotch brite 75218e76ed067f470d954fa7323fa088.jpg0d676032b4946f0e561f247424e19dd2.jpg
To me the frame looks bent! Do some measuring.
looks good man
Im Diggin the plastics!
Thanks man. I got a steal on this thing considering how clean everything is.
It's more then likely plastic not bolted down. It does kind of look like it, but notice daylight peeking through the rh side of radiator.
Sent from my SM-S820L using Tapatalk
^This. The plastic is not bolted down.
