Hello I'm kinda new to banshees and I'm going to add the timing plate and advance it 4 degrees then add Boyesen 645 Power Reeds, I was wondering if I could still run it on pump gas, and do I need to rejet the carbs. And with these reeds will they work with the stock cages. I have t5 pipes and k and n air filter, and tors delete. Thank you for your time.
+4 timing is good..
i went up on the pilot with reeds..
since you pretty well stock pump will be fine
If ur gunna get reeds do urself a favor and find urself a set of vforce 2s instead. If you do, then yes you will need to rejet because they will allow more flow.
Why 2's over 4's?
