Medicshee350
Everything posted by Medicshee350
  1. That's kinda what I was thinking, what would be a good set of reeds to change to since that would be all apart, and would a leak down test tell if the head gasket is bad?
  2. I was taking my airbox off and I noticed oil in the airbox boot that attaches to the carburetor. Then on the left side carburetor I saw antifreeze sitting just before the slide. Does anyone have some suggestions on what could be causing this?
  3. The bowls are correct, when I get a chance I'm going to set the timing to 2 dregrees and see if it's easier to start.
  4. I just checked and the cutaways are facing the rear.
  5. Yeah when i did the timing plate mod I also cleaned them and set the floats right, and I did a plug chip to make sure my jetting was still all good.
  6. I just advanced my timing 4 degrees and I'm having an extremely hard time starting it, the carbs were just fully rebuilt carbs are synced. But once it starts, it's first any time after that. And while riding it, it runs perfect. I have t5 pipes k and n air filter, tors delete parking parking braking delete, and recently advancing the timing 4 degrees. Could adaving the timing the 4 dregress be the problem.
  7. well both, on the right side it's all good the holes line up but on the left side the bolt doesn't line up and isn't leveled. And when I take the bolt out it's still not level. Sent from my iPhone using Tapatalk
  8. Johnson valley California? No its ocotillo Sent from my iPhone using Tapatalk
  9. here is a side view. Sent from my iPhone using Tapatalk
  10. Sent from my iPhone using Tapatalk
  11. No they where oem
  12. When I bought the quad it had different fenders that were cut, and when I bought full fenders and installed them they don't line up by the headlights, one is a lot higher then the other. why is this, is my frame bent? I would post a pic but idk how lol
  13. Hey I'm looking for a good set of pegs that would work with the stock heel guards, any suggestions?
  14. Hey I was looking into buy this grill, do you think it would effect my airflow? Or will it lead to easier over heating? I have an 02 banshee with t5s k&n air filter and 4 degrees of timing? Skull Flame Black Powdercoat Radiator Grill Guard fits: 1987-2012 Yamaha Banshee 350 - Ferreus Industries - GRL-132-01-Black https://www.amazon.com/dp/B00BD6WIL4/ref=cm_sw_r_cp_api_odROyb6SYR1QG
  15. If I advance my timing 4 degrees will I need to rejet, or will it be fine?
  16. Hello I'm kinda new to banshees and I'm going to add the timing plate and advance it 4 degrees then add Boyesen 645 Power Reeds, I was wondering if I could still run it on pump gas, and do I need to rejet the carbs. And with these reeds will they work with the stock cages. I have t5 pipes and k and n air filter, and tors delete. Thank you for your time.
