...please..I don't care about your nervous or your phone.. opinions are free..behave yourself.
Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
Are you a phone bomber?
Mmm, I have never think of that.. Maybe I have to join the Xmen academy to learn how to control my powers..
Wrong language in his sig for bomber!
This is the language of hairy girls and a bankrupted country. They also pray to zues.
It's not Murican. That means they are bombers.
  • Like 1
Did you change the spark plugs?
Are they gapped the same?
They are the same?
Reeds are tight? No chips/fraying?
Both pistons in correct?
Pipes are clean/clear?
I didn't really read through everything.
It isn't a carb issue. You only have one carb.
Your issues are limited to electrical, reed, air leak, or pipe.
You ruled out air leak.
Now check the reed on the right side and your pipe. Then check your stator/flywheel.
Leak down test was 100% good i did swap reeds and clean them there is not much electric on a shee i dont see anything that could cause this. Could a shitty porting job fucks the air fuel mix at a certain regime ?
Don't make me to blow up your phone's...
